1. AC Question's Avatar
    Yesterday during school I was listening to music on my phone and it suddenly died out of nowhere as soon as I turned it on the battery percentage gauge says 0 and the screen flickered under shut off after a little bit more usage Now when I turned it on it still says 0% battery and also if I plug it in it doesn't change either when I turn it off and plug it in and it would usually boot on into the charging screen the logo just turns on and is stuck in a boot loop please help
    10-22-2016 03:38 PM
  2. belodion's Avatar
    Probably the simplest way would be to get a new battery, and then read, and heed the content of, this:
    http://forums.androidcentral.com/sho...d.php?t=500054
    Rukbat likes this.
    10-22-2016 04:02 PM
  1. ZeroLemon S7 7500mah Battery Case Review
    By ChristianYe in forum Samsung Galaxy S7
    Last Post: 11-13-2016, 03:34 PM
  2. Replies: 1
    Last Post: 10-22-2016, 04:30 PM
  3. Replies: 2
    Last Post: 10-22-2016, 04:29 PM
  4. Replies: 0
    Last Post: 10-22-2016, 02:51 PM
  5. Why can't I change my background on Google hangouts?
    Last Post: 10-22-2016, 02:41 PM
