A
AC Question
Hi,
I have iBall Slide Q1026, it's got physical damage from charging pin. All tracks are damages related to charging point (as per the gentleman form authorize service center). First I sent it to service station and got repaired.
After repairing I found 2 new problems.
1. Charging very slow, if battery drains it took more than 13 hours to charge.
2. Volume too low.
After that I ask local provider to fix it. He is able to fix point no. 2 and point no. 1 is partially fixed.
In case of charging : It charge only when the tablet is switch off. In switch on case it does not charge. After few days again the tablet down. No charging on my tablet.
Local provider says we don't have circuit diagram to build a track with jumpers and some time it is possible that jumper get break when we connect charger pin.
Is there any way to rebuild the track without jumper so that this problem can be fixed permanently.
Please advice me.
2. Volume too low.
Please advice me.
