1. AC Question's Avatar
    I used otg bluetooth mouse on galaxy tab s2 8in
    Which led to instant battery drain and heating, I thought it was going to explode.
    I am not using mouse again for sure.
    But what could be the explanation?
    And will it happen again when I turn tab on?
    10-31-2016 12:13 PM
  2. Rukbat's Avatar
    OTG turns the phone into a power source for what's connected to the cable. (Normally, power flows into the phone on the USB port.) If the mouse is drawing a lot of power, that would cause the phone to heat up. Bluetooth mice don't need cables, except to charge the internal battery. Plug the mouse into your computer overnight (or into the phone's charger). Then use it without any cable connected to it until it needs to be recharged.
  3. Rukbat's Avatar
    10-31-2016 12:24 PM
  1. Battery life.
    By mekano14 in forum LG G5
    Last Post: 11-03-2016, 08:40 AM
  2. Those that came from a Note 7 - how is your battery life compared
    By Snareman in forum Samsung Galaxy S7 edge
    Last Post: 11-01-2016, 08:33 PM
  3. Replies: 3
    Last Post: 10-31-2016, 11:27 PM
  4. Droid Mini replacement battery
    By oscarmax99 in forum Ask a Question
    Last Post: 10-31-2016, 02:40 PM
  5. why is my phone running so hot and draining my battery
    Last Post: 10-31-2016, 01:20 PM
