Qi goes through the Commuter case (it makes the allowable "placement" a little tighter) so any Qi charger should work. (I use a Defender case, but the rubber is about the same.) And I use a LuguLake charging plate (which used to be $10, but is out of sight now, pricewise). It's nothing special - the normal 800mA Qi charger (which claims to charge at 1,000mA, but I've never seen that happen). I've charged on the Samsung "hockey puck" charger in the carrier's store, and that works too. Just make sure you get a charger plate with an indicator that the phone is sitting in the right place, and experiment with the proper placement for charging. (Mine works out to be just a bit lower than the bottom edge of the plate, and about 1/2" to the right of center.)
