Since last night, my phone has been absolutly killing my battery. At 64% battery it predicts it will last a little over an hour just on idle! I the only thing i have done is have a bit of a mess around with the tasker app i just got off the play store. I tryed to set up a task for my lock screen off when at home that required a third party app (called secure settings)which i downloaded, but halfway through realised you're phone needs to be rootedkmy LG G3 is not rooted) to complete the task. Not knowing much about rooting and tec stuff, i decided i was in over my head would wait, maybe research rooting before i get a head of my self. I then uninstalled secure settings and put my phone down with like 60% battery. 40 mins later i heard my phone go into power saver mode with 15% battery it has been like that ever since. At 90% my phone predicts just 2hours battery life. The Android system seems to be the culprit as it is showing 43% usage. Tasker has no other tasks on it and it makes no difference weather it is disabled or not. I have tryed turning my phone on and off again. I really dont know whats going on..Please help!
