1. Sharan SP's Avatar
    Hi, I have been using a sandisk 32gb class 10 sd card on my moto x play for about 4 months. But today after I shut down my phone and turned it back on, a notification saying "ejecting SD Card. Please wait" was visible. I can access my SD card on my PC but as soon as I put it in my phone I get the same notification saying ejecting SD card. I am unable to use it. Please guide me. I am no noobie to android so it doesn't matter if it's a long answer.
    11-13-2016 09:11 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. I wold turn the device off and reinsert the card into your PC again. See if it can detect any errors in the card itself.
    11-13-2016 09:21 AM
  3. Rukbat's Avatar
    It sounds to me as if the SD card port (in the phone) went bad. (If you're rough, you can bend a pin - which can start causing problems months later).
    Go to SanDisk microSD Tech Support, the upper right corner (chat live) and see if their tech thinks it could be anything else. (Their techs are good, and they'll lead you in doing whatever you have to do.) If it's the card they'll replace it, but I fear it's the phone.
    11-13-2016 03:24 PM
  1. Why have my contacts saved in sim card disappeared?
    Last Post: 11-13-2016, 03:31 PM
  2. How to Fix My Ascend Mate 7 !!! Please HELP !!
    By comec in forum Huawei Ascend Mate 7
    Last Post: 11-13-2016, 09:36 AM
  3. Found Trojan.FakeInst.E help
    Last Post: 11-13-2016, 09:20 AM
  4. Why does my phone say invalid SIM card?
    Last Post: 11-13-2016, 08:52 AM
  5. Replies: 0
    Last Post: 11-13-2016, 07:14 AM
