1. AC Question's Avatar
    On Samsung galaxy s4 charging screensaver keeps repestedly overriding document being reviews. Believe it is associated with DU Battery Saver which does not appear in application manager.
    11-16-2016 12:33 AM
  2. Tim1954's Avatar
    Go to playstore, find the app and you can uninstall from there usually...
    11-16-2016 03:04 AM
  3. jeffhaskins's Avatar
    If it is a downloaded app, but won't let you uninstall, you may have to remove it from device administrator list first. Then it should let you uninstall.
    belodion likes this.
    11-16-2016 05:07 AM
  4. Ramgopal Godara's Avatar
    04-01-2017 01:10 PM
  1. Way to get notification badge with Outlook app?
    By sprtfan in forum General Help and How To
    Last Post: 11-19-2016, 10:31 AM
  2. Replies: 1
    Last Post: 11-17-2016, 05:19 AM
  3. Replies: 1
    Last Post: 11-16-2016, 04:58 AM
  4. Note 5 How do I transfer pics to my Mac
    Last Post: 11-16-2016, 12:23 AM
  5. Replies: 0
    Last Post: 11-15-2016, 11:48 PM
