1. AC Question's Avatar
    So, my Note 5 crashed. I restart it. It shows me the Samsung opening logo and then goes to a black screen with the LED a continuous Blue color.
    I do a hard reset (Vol Down + Power Button), it repeats the action, Samsung Logo then black screen.
    I was able to get it to the Downloading, Do not turn off screen but after a couple hours sitting there, the battery drained out and died, I don't think it did anything while on that screen (How long does it normally take for that to perform).
    I've been trying to do a factory reset of the phone but this seems almost impossible due the fact that I can't even get it into recovery mode (get past the black screen, that is).
    Is my Note 5 salvageable? Is it bricked and should I just look into getting a new phone? I'm super bummed because I've loved my Note a lot.
    Is there a way to sell it if so?
    11-21-2016 11:11 PM
  2. chanchan05's Avatar
    The downloading part of the screen is the part where its supposed to be connected to a PC with a software from which it will ve downloading the firmware.
    It would help if you'd explain better as what you tried to do that may have caused the crash.
    11-21-2016 11:34 PM
  3. Entium's Avatar
    Nothing special in particular, just normal use. Nothing I would deem noteworthy. It's an unrooted phone, I did have Nova Launcher installed on it though.
    11-22-2016 06:03 AM
  1. Software updates and general support
    By Kayza in forum Axon 7 & Axon 7 mini
    Last Post: 01-20-2017, 11:29 AM
  2. Blu Life XL Keeps crashing
    By Emo hobo in forum General Help and How To
    Last Post: 11-22-2016, 09:58 AM
  3. How do I turn off my voice to text on my android2 phone
    Last Post: 11-21-2016, 10:12 PM
  4. Safe mode and sense home issue?
    By mwake4goten in forum HTC 10
    Last Post: 11-21-2016, 09:48 PM
  5. Note 2 bluetooth wont turn on
    Last Post: 11-21-2016, 09:30 PM
