1. AC Question's Avatar
    Can someone please advice how to change the phone info from *#*#4636#*#*, I am trying to change preferred network which is not also available in the Mobile Networks.
    How can I get rid of this error and update my required network type.
    Iam using LG Risio H343 - unlocked mobile.
    Thanks
    11-26-2016 11:17 PM
  2. Sohail Akram2's Avatar
    You should install app 4636 from google play store.i think this app will help you.
    11-27-2016 02:40 AM
  3. anon(632115)'s Avatar
    Its disabled on your device so the app won't work either
    11-27-2016 04:48 AM
  1. Replies: 2
    Last Post: 11-27-2016, 04:36 AM
  2. My S6 will not update from 5.0.2
    Last Post: 11-27-2016, 02:46 AM
  3. Cannot open Recently Open Tabs on Galaxy J3
    Last Post: 11-26-2016, 11:11 PM
  4. 6P won't turn on after 7.1.1 beta download?
    Last Post: 11-26-2016, 10:57 PM
  5. Im on Motorola G 4. How do i display my contacts by group?
    Last Post: 11-26-2016, 10:24 PM
