After i dropped it in water i turned it off and i put it on a bag full of rice 4 A week i then turned it on every thing worked fine exept charging......it takes 7 hours to charge on a fast charger ,changing the charging port didn't help ....
Let the device sit longer in rice. There could still be moisture. If the problem continues then there's likely permenant damage to the port or board. If that is the case you'll need to send the device for repair.After i dropped it in water i turned it off and i put it on a bag full of rice 4 A week i then turned it on every thing worked fine exept charging......it takes 7 hours to charge on a fast charger ,changing the charging port didn't help ....
