1. AC Question's Avatar
    So my phone is overheating and restarts after about a minute or so. I thought it might have been the battery but the heat was coming from some where else. So i opened it up and I believe its something under the SD card slot. Is there any tips or fixes anyone can give to solve my problem.
    12-24-2016 07:45 AM
  2. Rukbat's Avatar
    Running more apps causes more heat, so no. Note what? Note 7 Edge? If so, Note 7s were supposed to be turned in because ... they overheat. It's a design issue. (The Edge screen or not makes no difference.)
    12-24-2016 02:14 PM
  1. Samsung galaxy on5 hacked
    Last Post: 12-24-2016, 03:59 PM
  2. Composing Gmail in phone, is image possible only at the bottom?
    By Netherthorpe in forum Ask a Question
    Last Post: 12-24-2016, 02:38 PM
  3. Replies: 1
    Last Post: 12-24-2016, 05:37 AM
  4. Replies: 0
    Last Post: 12-24-2016, 05:32 AM
  5. how do i backup my saved internet pages on stock browser?
    Last Post: 12-24-2016, 04:28 AM
