1. AC Question's Avatar
    My battery settings are turned on for quick charge but when I plug in cable it turns the quick charge setting off
    12-26-2016 01:30 PM
  2. the tall guy's Avatar
    What are you using to charge the phone, is it the original cable that came with the device?
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    01-09-2017 07:27 AM
  1. mdnsd killing my battery
    By JDeckerVa in forum Legacy Android & Other OS's
    Last Post: 04-25-2017, 07:45 PM
  2. Need status icons for delivery reports on LGL62VL Premier
    Last Post: 01-09-2017, 04:52 PM
  3. Geting Ok Google to work on Note 4 from any screen?
    By michail71 in forum Ask a Question
    Last Post: 12-26-2016, 08:20 PM
  4. what to do wheni change my memery card
    Last Post: 12-26-2016, 03:53 PM
  5. Battery want charge
    Last Post: 12-26-2016, 01:06 PM
