1. AC Question's Avatar
    Just wondering if anyone has any idea what might be wrong with my Note 3. When I try to turn on WiFi, it just sits there with the subdued green you would normally see when it's transitioning from off to on but it never comes on.
    I have factory reset 3 times and cleared partition cache.
    Bluetooth DOES work. This is not the typical WiFi/BT problem.
    Thanks.
    01-02-2017 02:36 PM
  2. nahoku's Avatar
    Does this only happen at home? Have you reset your router? Does your router have IPv6 enabled?... disable it. Have you tried toggling Airplane mode? How about going into Airplane mode and turning on wifi? Have you tried booting the phone in Safe mode? None of this might work, but since you didn't state any of it, gotta ask.
    01-02-2017 03:03 PM
  1. Replies: 1
    Last Post: 01-02-2017, 11:54 PM
  2. I have a J7 is there a way to get the unlock swip affect on my phone?
    By BoopJamie121 in forum General Help and How To
    Last Post: 01-02-2017, 11:29 PM
  3. Change camera pixel size on LG4 cell phone
    Last Post: 01-02-2017, 07:49 PM
  4. Replies: 1
    Last Post: 01-02-2017, 03:12 PM
  5. Google voice detection turns itself on
    Last Post: 01-02-2017, 01:52 PM
