A
AC Question
Hey everyone, I have a Samsung Galaxy S5 G900A, it was charging no problem until I tried to charge it in the car, when I did it simply wouldn't charge, I tried several USB cables to no avail. I then tried to charge it from a house socket and it wouldn't charge from that either anymore. Once the battery ran out I plugged it in again and it showed a battery charging icon for about 10 seconds before changing to a battery icon with a yellow triangle with an exclamation mark in it. I have two battery's for the phone so I tried swapping battery's but that made no difference, I also tried cleaning the charging port, didn't work, I thought about the charging port but I then gently pushed the phone's battery connectors together a tiny bit and it started charging, which made me think it wouldn't be the the charging port. It got to about 15% but then stopped again, I tried moving the battery connectors around again but didn't work this time. If anybody could help I would greatly appreciate it, thanks, John.
