1. AC Question's Avatar
    when i try to turn it on, it just vibrates but doesn't respond and when i connect the charger it just shows 0% and turns blank..it repeats this.
    01-20-2017 05:00 AM
  2. belodion's Avatar
    That may need diagnosis by a repairer.
    01-20-2017 07:35 AM
  3. Ishu Dohare's Avatar
    i faced the same problem few days back...well the reason for the problem is that overcharging or using phone too much(like playing games while charging or charging the phone for too long) heats the charging IC of the phone and it sort of burns...so what u can do is ..go to a repairing shop and have ur phone checked out for the same..if the charging IC is not completely burnt..it might be fixed with little bit of soldering here and there..and if its completely burnt..ur phone might need a completely new charging IC...
    belodion likes this.
    05-16-2017 10:52 AM
  1. Replies: 1
    Last Post: 01-20-2017, 05:00 AM
  2. SMS converitng into MMS due to number of recipients
    Last Post: 01-20-2017, 04:54 AM
  3. lg g5 se doesnt read my texts on car stereo
    Last Post: 01-20-2017, 04:47 AM
  4. I can't find a conference call function on my Samsung A3.
    Last Post: 01-20-2017, 04:41 AM
  5. how do i fix my techno l8 it keeps hi launcher stop working
    Last Post: 01-20-2017, 03:18 AM
