Why does a blue light flash at the top of the phone?
A
AC Question
Just got new phone S6 and a blue light flashes on the top edge. Do I need to switch something off?
chanchan05
Q&A Team
Nov 22, 2014
8,519
It means you have an unread notification. For example you received a message while you were not looking at the phone and you didn't hear it. If you glance at the phone, there's a light, it means there's something you should read. It could be all sorts of notif.
