1. John Emmanuel Santos's Avatar
    Cell standby is at the top of my list in power consumers it has consumed about 2500 mah since the last full charge
    02-18-2017 07:10 AM
  2. belodion's Avatar
    What is your mobile signal strength?
    02-18-2017 07:32 AM
  3. Javier P's Avatar
    I agree with Belodion, it's possible that a weak cell signal could be the culprit. Tap on the battery graph and check the mobile signal bar. Also, it seems that your SIM 2 is on roaming, with data enabled and very weak signal. I'd bet this combination is at the root of the problem.
    02-18-2017 10:24 AM
  1. Replies: 3
    Last Post: 02-22-2017, 08:29 AM
  2. note 5 oem battery
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 02-18-2017, 07:36 PM
  3. Replies: 0
    Last Post: 02-18-2017, 04:01 AM
  4. note 5 oem battery
    Last Post: 02-18-2017, 12:25 AM
  5. How can I stop the voice notification on my LG cell phone?
    Last Post: 02-17-2017, 06:04 PM
