I stand corrected.
"Unfortunately, your LG Stylo doesn’t have Qi Wireless Charging integrated."
I looked into it initially and I received bad info. Thanks for catching it. In some cases, it doesn't matter if the phone is not exactly the same, as it is often the architecture of the inside that would allow 'compatibility', but in this case, looking into it further, the Stylo isn't even enabled for this upgrade.
