A
AC Question
I have had my Droid Mini for a few years, never had any major issues. For the last few days though, I've noticed the Android OS is the highest level on the battery use screen, at between 30%-40%. I never keep WiFi on constantly, I have all my apps set at the lowest use level, location at the battery saver mode, etc. I only turn on WiFi or Data when I'm on a break at work to check Facebook, etc. I've changed NOTHING in the apps that I regularly use yet the battery is draining super fast! I've done several searches over the last couple days to see what people in the same situation have done, but nothing seems to work (the cache clear was one). I've not downloaded any new apps on my phone in this time frame either, so really am at a loss as to what's going on.
