[MEGATHREAD - Gionee guest mode problems]
Pablurix
Forgot my guest mode passcode
I set up my guest mode passcode a while back, but i never changed my phone's password, so i forgot it and now i can't change it.
How do You change it?!? Help
My phone is a BLU Studio Energy
Re: how to remove password of guest mode if i forgot the password
Welcome to Android Central! You'll probably have to do a factory reset.
I forget my guest mode paspword
I have brought a gionee P5W phone and I have set the guest mode but unfourtunately I haven forgeten the paspword what shall I d??
Please help me
Re: I forget my guest mode paspword
Welcome to Android Central! Unfortunately, you'll probably have to do a factory reset.
How to turn off guest mode in gionee f103pro if i forgot password
How to turn off guest mode in gionee f103pro if don't know password? It's turn on by mistake
Re: How to turn off guest mode in gionee f103pro if i forgot password
Welcome to Android Central! You might have to do a hardware key factory reset.
Re: guest mode unlock?
Welcome to the forums. If you're the owner of the phone you can reset the guest mode thru your account.
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
I have forgotten my password for guest mode for gionee P4 how to remove guest mode now?
And even after 5 wrong attempts fogot password option is not appearing.
I forgot my gionee f103 pro guest mod password pls tell me what is my password, pls help me
I forgot my gionee f103 pro guest mod password, pls tell me my password , pls help me.
Re: I forgot my gionee f103 pro guest mod password pls tell me what is my password, pls help me
There is no way any of us would know your password.
How can i reset my password again in gionee s6s when guest mood is on?
Hi I am gionee s6s users. Guest mood is on and I forget my password now I am not able to use gallery call logs . How can I reset my password again?
HOW to get forget password of guest mode in gionee p7
Im so confused. I have gionee p7 nd by mistake i opened guest mode and i forget its password please reply me fast i cant see anything in my gallery s photos and videos
Re: HOW to get forget password of guest mode in gionee p7
Welcome to Android Central! What happens if you force a shutdown by pressing and holding Power for about 15 seconds, then power back on? Are you able to boot back into normal mode?
Chris 4502
