09-28-2021 07:58 PM
66 123
tools
    My phone is Gionee Android
    10-02-2018 10:29 AM
  2. belodion's Avatar
    That’s the end of the line then. You’ll have to factory reset, wiping all personal data not backed up.
    10-02-2018 11:52 AM
  3. Celes Fernandes's Avatar
    How to make under security Password protection visible activate and Guest password to reset forgotten password
    12-18-2018 06:11 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
    If you forgot your password, you're not going to find any system setting to recover it or change it. That would make it a very poor security measure. You'll either have to remember the password or do a hardware key factory reset (if possible). You might be asked for the Google account/password associated with the phone in order to proceed.
    12-18-2018 10:08 PM
  5. Chetan bhasker's Avatar
    How to make under security password protection visible activate and guest password to reset forgotten password
    01-06-2019 10:28 AM
  6. B. Diddy's Avatar
    Is there a reason you simply copied the OP's question? I'll just copy and paste my initial response again:
    01-06-2019 05:21 PM
  7. Android Central Question's Avatar
    I want to disable guest mode in my Gionee p4 without factory reset.
    01-12-2019 11:52 PM
  8. B. Diddy's Avatar
    Welcome to Android Central! Do you mean that you're stuck in Guest Mode and don't know the password to get out of it? Or that you just don't want the feature at all?
    01-14-2019 02:16 PM
  9. Android Central Question's Avatar
    As I have forgotten my password and also query question answer
    07-02-2019 02:14 AM
  10. Mooncatt's Avatar
    If you forgot your password and backup recovery answers (which makes your question seem extremely suspicious of being a stolen phone), then the only possible thing I can think of would be a factory reset. In doing so, you'll lose all data, and you'll also need to use your Google account login when you set up the phone again to prove ownership. I suspect you don't know that info either. If that's the case, you basically have a paperweight.
    07-02-2019 09:14 AM
  11. Android Central Question's Avatar
    My phone is gionee m5 so pls somebody help me I forgot my guess mode password...
    How can I get rid of it ?
    02-08-2020 04:24 PM
  12. anon(10614692)'s Avatar
    Reset your device is the only way
    mustang7757 and Rukbat like this.
    02-08-2020 04:52 PM
  13. mustang7757's Avatar
    'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    02-08-2020 04:55 PM
  14. B. Diddy's Avatar
    Welcome to Android Central! Are you able to force a shutdown by pressing and holding Power for about 20 seconds, then powering back on again?
    02-08-2020 05:13 PM
  15. Rose Smith3's Avatar
    Google play service is not working on my gionee f103 vision 5.0.2
    09-28-2021 07:42 PM
  16. B. Diddy's Avatar
    Welcome to Android Central! Does this have something to do with Guest Mode? That's what this megathread is about.
    09-28-2021 07:58 PM
66 123
  1. How'lol to disable guest mode in Gionee p4 without factory reset
    Last Post: 01-14-2019, 02:16 PM
  2. gionee mobile Under security Password protection is not visible
    By Celes Fernandes in forum General Help and How To
    Last Post: 01-06-2019, 05:21 PM
  3. I forgotten both guest password and security question
    Last Post: 10-02-2018, 11:52 AM
  4. Stuck with the guest mode
    Last Post: 08-19-2018, 06:46 PM
  5. How to decrypt the photos in gionee p7 max?
    Last Post: 08-04-2018, 10:14 AM
