I set up my guest mode passcode a while back, but i never changed my phone's password, so i forgot it and now i can't change it.
How do You change it?!? Help
My phone is a BLU Studio Energy
Printable View
Hello!
I would try logging into your Google Account on a PC and then go to Android Device Manager (https://www.google.com/android/devicemanager). From there you can setup a new password and GPS/Locate your device.
I enabled guest mode without the password and when I realized my messages and call logs were had hidden, l wanted to disable and I am asked to insert my password which I don't know.
Try using your Gmail password.
I forgot guest mode password of my phon gionee F103 .please help me to get back my password
I forgot my guest mode password of my phone gioneef103 give me help to get back
If you forgot it, there's not a lot you can do other than a factory reset to remove the account
My phone is Gionee p6.I have forgotten the guest mode password.i can't access my gallery and call logs.Any please help me?
Forgot password guest mode gionee m5 lite
Welcome to Android Central! There's probably not much you can do about that besides doing a factory reset.
Trying to put it off but couldn't off it
Welcome to Android Central! Is this the password to get out of Guest Mode? Is this your phone, or are you the guest?
I forgot my phone guest mode password in gionee f103 what should I do?
Welcome to Android Central! What happens if you power the phone off, then boot back up again?
The phone is gionee p6.
Welcome to Android Central! Does it matter if you reboot it? If you forgot the password, then you might have to do a factory reset: GIONEE Pioneer P6 - How to Hard Reset my phone - HardReset.info. This will require you to enter your Google username and password after the reset is done, before you can proceed to the Setup Wizard, since it will be regarded as an unauthorized factory reset.
I'm using Gionee F103 pro. I want to disable my guest mode on my phone. I don't even use password on the phone, and the disabling option is prompting me to put password. What should I do, I'm stuck.
Welcome to Android Central! Is it asking you to create a password, or enter a password in order to disable? Has this always been your phone, or did you get it from someone else?
my phone is gione M5
how to remove password of guest mode if i forgot the password in my gionee 34 in phone
Welcome to Android Central! You'll probably have to do a factory reset.
password
I have brought a gionee P5W phone and I have set the guest mode but unfourtunately I haven forgeten the paspword what shall I d??
Please help me
Welcome to Android Central! Unfortunately, you'll probably have to do a factory reset.
How to turn off guest mode in gionee f103pro if don't know password? It's turn on by mistake
