S7 edge battery drain from android system
  • Start date Start date
Hello there,
Clearing your Cache Partition on the device should get your battery back up and running.
Follow these steps. Be very careful and make sure you read the directions before entering recovery mode.
1. Ensure you have 40% battery
2. Power device off
3. Press and hold Volume Up, Home, and Power until you see the Samsung Logo, then release
4. If you are not in the recovery menu then you need to start back over
5. Using the Volume Down button, highlight Wipe Cache Partition
6. Select using the power button
7. Let the phone do its thing
8. Once it comes back into recovery mode, select reboot now
Hope this helps!
Hi I am the owner of a S7 edge. I don't know why but I see a new app draining the battery life. Do you know what is Android system custo
any idea ?
Hello there,
2. Power device off
Hope this helps!
If I do these. It will erase also the memory ?
GUYS I FOUND THE SOLUTION!
So i sum up all the problems regarding android system battery drain in s7 edge and after applying this settings i got my battery running normal again.solutions are as follows
1. Clear data from google services
2. Force stop chrome , facebook
3. Smart alert off
4. In oreo restrict background usage of android system
5. Check that your cell signal are not low
6. Wifi always turn on select never
7. Google backup off
I applied all those settings and in upcomming time i will check what was the give culprit
BrüZZi
