1. AC Question's Avatar
    Recently I've noticed that in calls, the volume in the ear piece speaker is very quiet and when I use the volume rocker to change the volume in calls, there is no change in volume at all. I've factory reset my phone to eliminate any apps that may be the problem and no change in volume. I do not know if it was a recent update that caused this problem but any help would be great.
    03-29-2017 11:56 PM
  2. Tim1954's Avatar
    Give the shiny metal bits a polished and inspect the hole for debris maybe...
    03-30-2017 12:20 AM
  1. Is there a Note Galaxy S8?
    By cwhittaker53 in forum Samsung Galaxy Note 8
    Last Post: 04-02-2017, 11:15 AM
  2. Icons are ugly, can you change it back to the old ones?
    By jeffhuypham in forum Samsung Galaxy S8 & S8+
    Last Post: 03-30-2017, 06:58 AM
  3. Replies: 1
    Last Post: 03-30-2017, 12:57 AM
  4. Air View...Is it Back?
    By monicakm in forum Samsung Galaxy S8 & S8+
    Last Post: 03-29-2017, 10:59 PM
  5. Galaxy note 4 crashing and will not restart until plugged in??
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-29-2017, 10:51 PM
