1. AC Question's Avatar
    My battery life has been bad for a while, but this week it took a major turn for the worse. At this point, it doesn't matter how charged it is...if i plug it from the charging cord and try using almost any app, it'll shut down immediately. I can't turn it back on unless i plug it in, and when i do it'll say the battery is at some random percentage of being charged. It'll stay on unplugged as long as i try use it at all, but as soon as i use anything.. CRASH. What do i need to do? Any advice will help thanks.
    04-04-2017 09:17 PM
  2. belodion's Avatar
    You may need a new battery.
    04-05-2017 04:42 AM
  1. Tips to customize the Honor 8
    By digitalbreak in forum Community Reviews
    Last Post: 04-09-2017, 12:59 PM
  2. Hardware keyboard case is only for the Plus version?
    By BeyondtheTech in forum Samsung Galaxy S8 & S8+
    Last Post: 04-06-2017, 05:55 AM
  3. Is there any way to fix ny speaker problem on my samsung s7
    By Izzy141 in forum Samsung Galaxy S7
    Last Post: 04-05-2017, 09:55 PM
  4. Replies: 2
    Last Post: 04-05-2017, 10:07 AM
