1. AC Question's Avatar
    It never has done this, but I have come across the same problem with other cables and it's annoying. I have to BEND the microUSB end while it's inside my phone to charge properly. One time I did this with an older charger and the thing just snapped off.
    Why does it keep switching from Charging, (phone%) to Disconnected, (phone%)
    Why do I need to damage my own working and functional cables so that they work?
    04-10-2017 08:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! This happens with other cables as well when you use them with this phone? If so, then it's probably an issue with the phone's microUSB port, where there is probably a loose connection somewhere. But if it only happens with that one cable, then that cable is failing.
    04-10-2017 04:57 PM
  1. How to get out of kid mode - HTC one
    Last Post: 07-27-2019, 11:17 PM
  2. Replies: 2
    Last Post: 04-18-2017, 03:21 AM
  3. My wallpaper theam is not changing
    Last Post: 04-10-2017, 05:03 PM
  4. Replies: 1
    Last Post: 04-10-2017, 06:51 AM
  5. Can someone get into my phone and turn my sync off
    Last Post: 04-10-2017, 06:47 AM
