1. AC Question's Avatar
    I have a Samsung galaxy a3 2016 and the battery percentage is going down instead of up while charging. I tried different cables and charging with a laptop. What do I do?
    04-16-2017 09:03 AM
  2. jasonandrews25788's Avatar
    most probably it's because of a Swollen Battery.
    04-16-2017 08:31 PM
  3. Morty2264's Avatar
    Welcome to the forums! Is the phone quite hot in your hands while it's charging and going down in percentage? When did this start happening? How long have you had the phone? If it's very hot, unplug it and shut it off; and bring it to your local carrier or to where you purchased it and try to get a replacement. Please keep us updated!
    04-16-2017 09:17 PM
  1. Is my huawei p10 battery faulty or normal?
    By AC Question in forum Huawei P10 & P10 Plus
    Last Post: 04-16-2017, 02:22 PM
  2. does i9505 charging flex is support in i9506 or not?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-16-2017, 06:57 AM
  3. does i9505 charging flex is support in i9506 or not?
  4. Is my huawei p10 battery faulty or normal?
    Last Post: 04-16-2017, 04:52 AM
  5. Samsung GSM-G600 Batteries.
    Last Post: 04-16-2017, 04:03 AM
