1. AC Question's Avatar
    When I recently purchased my Lenovo tablet the battery charge was down to 23%. I understand that if the charge falls below a certain level it can damage the battery. Is 23% low enough to cause damage or is this ok? I have charged the battery a few times since I bought it and it seems to be holding a charge OK. Any advice really appreciated.
    04-17-2017 03:44 AM
  2. Tim1954's Avatar
    They half charge them before packing. Depends on how long it sits on the warehouse shelves, they do go down a bit.
    Just charge it full and carry on. That shouldn't harm the battery, don't run them down to zero or they will fail. It should be fine. Welcome to the forums! :-)
    04-17-2017 05:00 AM
  1. why go sms diy theme is not working?
    Last Post: 04-17-2017, 08:53 PM
  2. Replies: 1
    Last Post: 04-17-2017, 10:38 AM
  3. J2's backlight is flickering (and also flashes bright light)
    Last Post: 04-17-2017, 04:57 AM
  4. when will samsung will provide nought update for J5 prime?
    Last Post: 04-17-2017, 03:26 AM
  5. Replies: 0
    Last Post: 04-17-2017, 02:13 AM
