Why has android.process.media atopped and how do I fix problem
  • Start date Start date
Welcome to Android Central! The SD card could be corrupt, defective, or counterfeit. Install SD Insight to see if the card is genuine or counterfeit. Counterfeit cards are programmed to report more storage than they actually have, and if you try saving more than the card can actually hold, then files can start getting corrupt. (Be aware that SD Insight might not work on all Nougat devices.)
If it's a valid card, then go to Settings>Storage, Unmount the card, remove it, and insert it into your computer. Can the computer read these files? Backup as much as you can right now, then run chkdsk to look for bad sectors: [GUIDE] Using chkdsk to fix a corrupted SD card - Android Forums at AndroidCentral.com
ChrisAndroid
