A AC Question May 6, 2017 #1 the charging port of My CM flare s3 is lost . can i change the charging port of my CM s4 lite to CM s3 ?
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,364 110 63 Visit site May 7, 2017 #2 Welcome to the forums. If you can find the part numbers for both parts and compare them that might tell you if they are interchangeable. If I had to guess right now, I would say probably not. Upvote 0 Downvote
