1. Leedsboi86's Avatar
    Hey everyone
    Got a quick question about the battery drain on a Samsung S7 Edge,
    Battery Usage: 4H 12M
    Screen on time: 1H 45M
    Battery is drained from 100% to 70% in 4 hours with the above usage.
    Does this sound about normal for draining or is it quite high?
    Only really used the phone for whatsapp and browsing a bit of facebook via app,
    Screen is set to WQHD and about half or just over on the brightness slider.
    any advice would be great, I've not used the samsung for long so wanted to check if this was normal drainage level or if something was wrong.
    thanks again.
    05-10-2017 06:58 AM
  2. YouBlue_dev's Avatar
    I'm at 75% after 4.5 hrs. It really depends how often you're using it. You can check your battery settings to see which apps are using the most power. If there's something that doesn't look right, consider removing that app.
    05-10-2017 11:08 AM
  1. Replies: 3
    Last Post: 05-10-2017, 10:05 AM
  2. How to fix these samsung s8 problems.
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-10-2017, 08:41 AM
  3. Replies: 1
    Last Post: 05-10-2017, 06:31 AM
  4. Replies: 0
    Last Post: 05-10-2017, 06:06 AM
  5. Replies: 0
    Last Post: 05-10-2017, 05:51 AM
