1. AC Question's Avatar
    I have this Note 4 for almost 2.5 years......4 days ago my original fast charger stopped charging...so I got new one.....it worked one day and next day again stopped charging my mobile. If I connect only wire to laptop......it charges fine. I got replacement this morning for new charger and decided to observer phone when charging.....nearly after 1 hour.....I heard a small noise from adopter like the fuse is gone or something burnt inside. And it stopped working again......dont know what to do?
    My mobile is working fine once charged.......but this way I will loose all the adopters in the world!! Please help.....
    05-10-2017 12:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Where are you getting the replacement charging plugs from? Are they OEM, or 3rd party? Try to get a genuine Samsung charger.
    05-10-2017 12:55 PM
  3. wadalwat's Avatar
    Hi Thanks for your reply.....my 1st charger was an original charger which I used for 2.5 years..2 new chargers I bought were from a local Chinese shop.....
    Do you think if I buy original charger then this should resolve problem? Or should I replace a battery?
    05-10-2017 01:17 PM
  4. B. Diddy's Avatar
    I'd try a genuine charger first before trying to replace the battery.
    05-10-2017 04:12 PM
  1. My Note 4 can't boot normal..
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-26-2017, 10:47 PM
  2. Can a Sprint Note 5 N920P LCD be put on a n920c note 5
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 05-18-2017, 12:37 PM
  3. Replies: 1
    Last Post: 05-10-2017, 08:18 AM
  4. Exiting Max power saving mode leaves :ok google: dead
    By Fred P in forum Legacy Android & Other OS's
    Last Post: 05-10-2017, 04:28 AM
  5. My Note 4 can't boot normal..
    Last Post: 05-10-2017, 03:46 AM
