1. AC Question's Avatar
    My asus transformer will not charge & no orange light comes on when charger is connected to it
    05-10-2017 12:06 PM
  2. bmhillegass87's Avatar
    Hello!
    I know i'm stating the obvious here, but have you tried a different micro-usb cable? Perhaps a different wall outlet or wall charger plug? Sometimes, you'd be surprised how quickly it will fix an issue like you mentioned above. Fingers crossed its not hardware related! How long ago did you make your purchase? Did you purchase any additional warranty? Those would be my follow up questions if the alternate cable/charger doesn't work. You still might have some additional options!
    05-10-2017 12:14 PM
  3. anon(9602380)'s Avatar
    Do you have any other device you can try it with or possibly a friend with a compatible device that you can try to see if it's able to charge. That should tell you if it's working or not. Thanks.
    05-10-2017 12:29 PM
  1. Battery Drain in 11 hours after using Dr Fone
    By jaz572 in forum Samsung Galaxy S6
    Last Post: 05-22-2017, 11:37 AM
  2. What is best for charging my Samsung 6
    By Whatdafk7 in forum Samsung Galaxy S6
    Last Post: 05-10-2017, 02:49 PM
  3. Replies: 1
    Last Post: 05-10-2017, 01:10 PM
  4. Replies: 1
  5. Replies: 0
    Last Post: 05-10-2017, 11:57 AM
