1. AC Question's Avatar
    Alright so I'll keep it simple the recent 7.0 update causes the audio output to automatically switchback to Bluetooth device if it is used to pause or play music. Even if manually set to a different output it will revert back. Never had this issue before this update hope there is a fix.
    Example
    I connect phone to a portable wired speaker. Connect bluetooth headset to control music. Set audio to speaker. Pause music then play music using headset.
    Audio reverts back to bluetooth everytime
    05-11-2017 01:17 AM
  1. How to get full access to my. Ext. SD card marshmallow
    By Michael1962 in forum Android 6.0 Marshmallow
    Last Post: 05-11-2017, 02:01 PM
  2. Anyway to avoid factory reset for locked note 5 ?!
    Last Post: 05-11-2017, 01:35 PM
  3. can I connect my tablet to the internet throgh my computer?
    Last Post: 05-11-2017, 01:34 PM
  4. Replies: 1
    Last Post: 05-11-2017, 01:33 PM
  5. Replies: 4
    Last Post: 05-11-2017, 12:08 PM
