Battery drain on my meizu m3 note
Luca97
8
Hello!
I noticed a battery drain of 5/6% every 8 hours. I have flyme 5.1.12.0G onboard . after red some treads I tried to install the latest beta of google play services( 11.0.33b)and wow, it seems i solved the problem. Only 1 percent every 8 hours.
But after a Week the problem has return. I also tried to switch to the last flyme 6 beta but nothing has changed. What could it be the problem?
Sorry for my bad English :-I
Luca97
8
Sorry, i forgot to put some screenshots
Luca97
8
Thanks You
The problem is the battery drain. I was hoping someone would look at these screenshot and tell me what could be the cause of this problem.
Two days ago I downloaded and install flyme 6.7.4.11G from an official tread on flyme forum.
The First day everything was fine.The second day the problem has reappeared
Luca97
8
Hai perfettamente ragione, chiedo scusa.. Comunque, penso di aver dato abbastanza informazioni insieme a degli screenshot ma se passano giorni e nessuno mi risponde forse mi viene da pensare che nessuno voglia aiutarmi
Aquila
Retired Moderator
Feb 24, 2012
15,904
I think people want to help, but are confused with a couple things, like Flyme. It definitely looks like you've got something spinning that doesn't necessarily need to be. My first guesses would be low cellular signal, location scanning or Wi-Fi/BT scanning. Unfortunately I'm not familiar with that device to know for sure.
Luca97
8
I'm currently using the 6.7.4.11G firmware. I disabled GPS, contacts sync, and google fit since I do not have applications that use it. I usually put the phone in airplane mode overnight but doesn't change anything.
Low cellular signal? I don't know but the telephone signal looks good
