What is the little battery with the recycle triangle and how to get rid of it
A
AC Question
How do i get rid of the little battery with the triangle in it
Mr Mendelli
451
That is your battery saver, it means that when your battery reaches a certain percentage it will switch to this mode to save power where it can. To check your options for the battery saver, open settings and navigate to:
Battery> Battery saver
