1. AC Question's Avatar
    Hello.
    Basically my Note 4 had hardware failure, so I bought an S7 Edge. However I managed to get it repaired. Shall I keep the S7 Edge and pop a new sim or return it? Are the differences much?
    05-24-2017 08:35 AM
  2. Morty2264's Avatar
    Welcome to the forums! While the Note 4 is great, perhaps keep both phones and have the 4 as a backup in case something happens to your Samsung device. It's always good to have a phone on standby, just in case! Glad your 4 got fixed!
    05-24-2017 09:09 AM
  3. jackjoe1234's Avatar
    I made the op, for some reason I can't always log in, so I use guest which is bad lol.
    So it's a good idea to keep? I had another Note 4, hardware failure but it's not under warranty. So I just left it in the box. My Note 2 also has hardware failure, however the phone is kinda old now and also not under warrany. I'm not sure if Notes break often, or maybe I just have bad luck? Even the other day my TV broke, I had to replace it!
    I have two sim only so I've put my Note 4 contacts/apps backup on the S7 Edge. Haven't copied over photos and videos since it's not needed on both phones. Main reason I bought the S7 Edge was because I have events coming up, and was told it'll take 10 days to fix my phone, it took less than 24 hours. In fact, my repaired phone came back before my ordered one.
    05-25-2017 02:01 AM
  4. Joseph Guy1's Avatar
    What ever you do don't update to 7.0 on the edge for some odd reason after I updated the screen was very dim and no auto was off I had exchanged the phone and was just fine before update then same thing after update
    05-25-2017 02:42 AM
  5. jackjoe1234's Avatar
    Ouch, I've had an update pending since yesterday too...
    05-25-2017 02:46 AM
  6. jackjoe1234's Avatar
    I think I may return it. I just don't see myself needing two phones, although it is a really good phone.
    05-26-2017 01:40 AM
  7. I_didnt_do_it's Avatar
    Heck, you could sell that thing for some decent cash. It is a good idea to consider keeping in the event of the s7 edge going down. I just purchased an HTC One m8 for $75 to backup my s6 edge in case it fails, or has something else happen to it.
    05-26-2017 02:51 AM
  1. Replies: 1
    Last Post: 05-24-2017, 03:54 PM
  2. Replies: 1
    Last Post: 05-24-2017, 02:52 PM
  3. Replies: 1
    Last Post: 05-24-2017, 07:45 AM
  4. Phone keeps restarting and then some
    By Gibby105 in forum Samsung Galaxy S7
    Last Post: 05-24-2017, 06:39 AM
  5. what is the role of wifi wps(master or client) in android 6?
    By VINOTHKUMAR S in forum Legacy Android & Other OS's
    Last Post: 05-24-2017, 05:01 AM
