Beeping noise every minute on calls Galaxy S8 HELP!!!
  • Start date Start date
A
AC Question
I just recently did the update to my galaxy S8 and now I hear a beeping noise every minute while I'm on a call. Does anyone else have this issue? I have Sprint. It's driving me crazy.
Welcome to Android Central.
Sounds like you may have Notification Reminders on.
To turn off repeat (unread) alerts on your Galaxy S8, follow these steps:
1. From your device’s Settings, tap Accessibility > Notification reminder.
2. Slide the switch to the off position.
3. Make sure the switch beside the Phone app is turned off.
Hope this helps.
coder4242
