How do I fix system UI?
  • Start date Start date
A
AC Question
I go to screenshot by swipe or buttons and my phone comes up with 'system UI has stopped notification and doesn't take a screenshot. I have to press okay then the message repeats another 5 times before it goes away. I have a samsung galaxy A3 (2015)
Welcome to the forum. Messages like this are very difficult to troubleshoot because they may be caused by many things. I would suggest you reboot the phone a couple times and see if that helps. Next step would be a soft reset, I don't have an A3 but doing a Google for how to soft reset your model of phone should turn that up for you. Sorry that doesn't help much.
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
successlegacy
