1. AC Question's Avatar
    Are thete settings on the S8 that make wireless charging faster?
    06-04-2017 05:28 PM
  2. anon(238680)'s Avatar
    Welcome to the forum. Once you do a fast charge there will be a fast charge toggle under the Battery settings, but that is to disable or enable FC. There are no settings to choose how fast charging is. If you have an older charger that may make a difference as there are newer ones for the S8 phones running Nougat.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    https://forums.androidcentral.com/as...community.html
    06-04-2017 05:46 PM
  1. Swapped phones for a month lost new contacts
    Last Post: 06-04-2017, 04:54 PM
  2. Why am I being kicked out of any Settings sub-menu?
    Last Post: 06-04-2017, 03:41 PM
  3. how do i add a rejection message for incoming calls
    Last Post: 06-04-2017, 01:47 PM
  4. Please help for repair note 5
    Last Post: 06-04-2017, 12:06 PM
