A
AC Question
Within the last couple of months, my phone will not connect to my bluetooth speaker (both a stand-alone speaker as well as in-car system) on incoming calls only. I can make outgoing calls via bluetooth just fine, but when I try to pick up an incoming call, the bluetooth simply doesn't register. It's as if it isn't even paired with a speaker at all. If I toggle bluetooth off and then back on, it works, but that's not safe while I'm driving and kind of defeats the purpose of bluetooth.
Here's what I've tried:
- unpairing and re-pairing my phone with the bluetooth speakers. No change.
- wiping out the cache partition. No change.
I really don't want to do a factory reset because I invariably lose some settings or data or documents or stuff.
Any ideas??
Any ideas??
