Welcome to Android Central! That might mean a problem with the battery or motherboard. Try pressing and holding Power and Vol Down together for about 15 seconds to see if it turns off. Then plug it into a wall outlet overnight, and then try powering on by pressing and holding Power for about 15 seconds. If nothing happens, you'd probably have to bring it to a repair shop.
