1. AC Question's Avatar
    I turn my volume to the max and I see it is on max thanks to the volume thing that pops up on the screen but a second later I see the volume going totally off (to vibrate) and I see it happen on the screen as well. But I haven't even touched the volume button and the volume turns off. Then, my phone goes into reboot. Apparently, reboot is activated by pressing the volume down key but I didn't touch the volume down key.
    06-16-2017 09:57 PM
  2. anon(9602380)'s Avatar
    Welcome to Android Central.
    I suggest trying a hard reset. Hold your power and volume down button at the same time till you see it restart. Then let go of the buttons. Hopefully this will help with your issue. If not it is possibly a hardware issue and I suggest having it looked at. Thanks.
    06-17-2017 12:12 AM
  1. Can I connect my Motorola Droid Turbo to my TV?
    Last Post: 06-17-2017, 11:53 PM
  2. Why won't my Nexus 6P find Nougat Update
    Last Post: 06-17-2017, 11:51 PM
  3. Replies: 1
    Last Post: 06-17-2017, 11:50 PM
  4. How to connect on google server
    Last Post: 06-16-2017, 11:46 PM
  5. Replies: 1
    Last Post: 06-16-2017, 10:55 PM
