Fix Touchwiz Home problem : empty menu + home page problems + ..
  • Start date Start date
A
AC Question
Hello Android Guys,
I recently have a problem with my S4 TouchWiz Home.
I often have the Menu empty from apps.
The home page sometimes gets empty too, the folders inside it wouldn't open, or the widgets inside it won't work properly.
This is in addition to other bizarre same problems.
I tried to reboot my phone, but sometimes it works some moments before getting back to the same state again.
So, after I tried looking in the internet -> haven't found similar problems. (maybe you can)
Then, I tried deleting the app data and its cache. It works for some moments sometimes but with the same behaviour afterwards.
I know you are very talented here. I hope you can help me find a solution to this problem.
Thanks in advance. :D
maskasuba
