How to Recover data from an internal encrypted SD Card (with a bigger problem)?
  • Start date Start date
A
AC Question
Hello Everyone:
I know there is a thread about this topic, but its not fitting my case:
I had a Moto G3 with a 32 SD Card memory, which I formatted as internal memory.
The thing is that I got mugged, but I got to keep my SD Card.
As I knew that the data was still in the SD Memory, I didn't touch it since then, hoping some day I get a solution.
So the question is the next one:
Is it possible (In any way) to recover data from an encrypted SD Card, without having the phone which encrypted it???
Ps: Sorry for my bad english, im argentinian.
What do you mean by saying it is an "encrypted SD card"? Was it formatted as internal memory, or did you really encrypted it in some way?
Anyway, if you can read the SD card in computer, then you may try a file recovery tool.
Or, it might be impossible to recover data from an encrypted SD card without decryption.
Hello Thacy, I meant Formatted as Internal Memory.
When I plug the SD Card to my computer, it detects it, but it says it has to be formatted to use it
Marlene
