1. AC Question's Avatar
    Hi,
    my note 4 was automaticly updatet last week (official update, android 6.01, some security updates, baterry drain optimization, etc) since then it keeps loosing mobile data connection. When I use, or try using internet the connection is going on for few seconds, off for few seconds, on for few seconds , off for few seconds,...
    I had never experienced those problems before.
    It's happening only while roaming, in my home network everithing workss fine.
    06-26-2017 05:48 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-28932
    06-26-2017 12:02 PM
  1. Why does my battery drain so fast since installing Samsung update?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 06-27-2017, 06:30 PM
  2. Why i dont have any ringtone on my samsung a5
    By AC Question in forum Samsung Galaxy A5
    Last Post: 06-26-2017, 12:04 PM
  3. Replies: 1
    Last Post: 06-26-2017, 07:37 AM
  4. How do i sync my google photos to my gallery?
    Last Post: 06-26-2017, 06:02 AM
