1. AC Question's Avatar
    My Samsung S4 started showing a strange power alert recently. The app alerts me that my device has gone below 35% power and suggests that I turn off my wireless. Strangely it keeps the screen lit up (sometimes for hours) until the phone dies or the user 'cancels' the alert. I can dismiss the alert then it takes me to a strange settings page showing on/off sliders for 'Selfie Backgrounds' 'Sleep Sounds' 'Daily Zodiac' and 'Phone Ring Mode Alerts'
    I haven't downloaded anything new on my phone for at least a month and I'm unable to identify anything running in the background. The screen shows no identification for the program.
    Has anyone else had this issue?
    07-05-2017 08:46 AM
  2. belodion's Avatar
    🙋I'm not familiar with Samsungs, but does this persist in Safe Mode? https://forums.androidcentral.com/sh...d.php?t=409154
    07-05-2017 09:37 AM
  3. zebra61's Avatar
    Good point, I haven't tried that yet. I'll report back on my findings. In the meantime here's a screenshot of the offending program/virus/widget?
    07-05-2017 08:24 PM
  4. zebra61's Avatar
    Safe mode gives me the same results. I might have to do a complete reset to smoke this out...
    07-05-2017 10:39 PM
  5. hkauer's Avatar
    Same annoying popup here on a Samsung Galaxy Note 3. Cannot find any other comments in the net than this.
    Have you already found a solution?
    07-07-2017 01:58 AM
  6. hkauer's Avatar
    07-07-2017 05:15 AM
  7. schauk's Avatar
    This is driving me nuts! I could reset my phone, but I rather would like to know what is this app? How did it install itself here? Can anybody help?
    Avast found nothing.
    Malwarebytes found nothing.
    It's not listed in currently running apps on ShutApp.
    It's not listed in Accessibility apps.
    There is a guy in Notifications that is suspect, GlanceViewMk... I'll disable it to see what happens.
    07-07-2017 04:29 PM
  8. zebra61's Avatar
    Safe mode did NOT stop the application from running. There have been threads pointing the finger at Peel Remote so I disabled that to see if there's any improvement.
    The most hateful part of this is the fact that the notification lights up on the screen and won't go back to sleep unless the user clears the notification. 35% battery life turns to 0% pretty fast when that happens.
    07-07-2017 04:58 PM
  9. zebra61's Avatar
    I disabled Peel Remote and also went into Settings> Sound & Notifications > Notification Access and unchecked something called "GlanceViewMk". So far the strange (and very annoying) lock screen has not returned. I can't tell you which of these moves is preventing the program to run but this is better. Truthfully I'd like to know that it's fully removed... not just disabled.
    07-07-2017 11:41 PM
  10. hkauer's Avatar
    I also disabled Peel Remote yesterday. Since rhen the mysterious notification did not appear anymore.
    Not really a solution but at least a workaround. For sure this is a disturbing behavior of an app.
    07-08-2017 12:01 PM
  1. LG G6 a flop? Low sales?
    By flyingkytez in forum LG G6
    Last Post: 08-20-2017, 10:58 AM
  2. Application for battery saving when holstered.
    By undefinederror in forum Android Apps
    Last Post: 07-09-2017, 12:12 AM
  3. LG v20 low antutu benchmark score of 113k
    By AC Question in forum LG V20
    Last Post: 07-05-2017, 10:19 PM
  4. why is "Save to SD Card" greyed out in application manger?
    Last Post: 07-04-2017, 02:08 PM
  5. Strange warbling when using my Moto X Force in a slide-up wallet case
    By MotoFanUK in forum Android 6.0 Marshmallow
    Last Post: 07-04-2017, 01:52 PM
