1. AC Question's Avatar
    Hi All,
    I turned the Ultra Power Saving Mode and after sending a few text messages locking and unlocking the phone it froze for a moment so I restarted the phone. Now It shows me the normal home screen and I can access my apps page but everything is turned off and I cannot turn Ultra Saving Mode off. I tried restarting it, taking the battery off and putting it back on. Anyone seen this that can help me figure this out?
    Debaprotim Bayan likes this.
    07-15-2017 02:03 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What if you boot into Safe Mode?
    07-17-2017 01:53 PM
  3. Debaprotim Bayan's Avatar
    is your problem solved now?
    08-18-2018 10:59 PM
  4. Debaprotim Bayan's Avatar
    Hi All,
    Is your problem solved or not and if solved then how did you solved it. Please reply
    08-18-2018 11:02 PM
  1. Samsung S7 slow loading facebook, OneClick and Overdrive
    Last Post: 07-17-2017, 01:55 PM
  2. I am stuck on the logo with the 2 dogs and RCA
    Last Post: 07-17-2017, 01:53 PM
  3. S8+ screen shadow on edges ?
    By simi_id in forum Samsung Galaxy S8 & S8+
    Last Post: 07-15-2017, 01:56 PM
  4. guest mode unlock?
    Last Post: 07-15-2017, 01:01 PM
  5. Replies: 0
    Last Post: 07-15-2017, 12:53 PM
