When you leave the house you lose your wifi connection. If you restart just WWF, it should connect you back (from the start, though, not from where you left off). That's how most websites work - they don't keep track of where you are. If you disconnect, then reconnect, you start over. Losing your wifi connection is disconnecting, and you're not the same "you" when you reconnect over mobile data.
