1. AC Question's Avatar
    I have a MotoX which I dropped in water yesterday. Only the top had contact with the water, I quickly turned off the phone and wiped the phone and ports with paper towels. I tried putting it in rice, but i noticed that the rice was gettingstuck inside the audio jack.
    It turned itself on after an hour of charging, and it said it was on safe mode, I searched up how to disable this, however my power keys ad volume keys wouldn't function. Also, the alarms and ringtones were functioning but the music I couldn't listen.
    I tried to drain its battery in order for it to shut down overnight. In the morning it was back on AP Fastboot Flash mode S
    30.BE
    eMMC:16GB Sandisk RV=06 PV=07 TV=17
    DRAM:2048 Elpida S4 SDRAM DIE:4GB
    Up time: 2 minutes
    Device is LOCKED Status code:0
    Battery LOW
    Charger connected
    Boot mode selection MEnu
    Normal powerup
    recovery
    factory
    Barcodes
    BP tools
    Fastboot reason: Key presses
    Charger connected
    There was water in both the cameras last night, however now it's not there. I have already moved all my photos onto my laptop.
    I have dropped my phone in water ; completely submerged,once before,and I turned it off. When it was turned on the next morning, it worked completely fine.
    How can I tun it on and disable safe mode if possible??
    07-21-2017 04:32 AM
  1. Will you buy the coral blue s8 or s8+?
    By deadp1xel in forum Samsung Galaxy S8 & S8+
    Last Post: 08-02-2017, 07:46 PM
  2. Phone freezes and won't launch apps
    By ckfilmstar in forum Axon 7 & Axon 7 mini
    Last Post: 07-25-2017, 08:34 AM
  3. Galaxy Tab S2 - Getting the dreaded NET::ERR_CERT_AUTHORITY_INVALID message
    By PeterSWLondon in forum Samsung Galaxy Tab S2
    Last Post: 07-25-2017, 02:32 AM
  4. Creepy photos on my phone
    Last Post: 07-21-2017, 04:28 AM
  5. Unable to music from Samsung s6 in my through AUX cable
    Last Post: 07-21-2017, 03:18 AM
